00 6.5 Cruise question
tanman_2006
Just a farm kid...
Seiling, Oklahoma
Iirc, on DS4 trucks they are programmed for cruise even if not equipped and the multifunction switch with cruise equipped one.
Is there anything else to adding cruise? I am looking at a 00 C3500 HD 6.5 with new IP, pmd relocation, and new NV4500 and clutch. It is a base model with out cruise, my first mods were going to be cruise, a team, and exhaust.
I am not sure, but I believe that the wiring plug might actually be there.
Does it have tilt or just the rigid column? do you plan on adding tilt if it doesnt?
the reason I ask is that if it does not have it, will probably have to order a non-tilt cruise equipped switch. if its lucky enough to have tilt, then the switch I posted will work.
