Thanks. I really hope I can get more articles done this year.
Maybe we can do one on your coating over a Mishimoto or Griffin radiator with before and after numbers? : )>
Sure, if you can find access to a double head torch I could send you 2 Thermal barrier test samples and you could run a heat barrier test as a independent source and show the result's. It's the product I use in the runners to stop heat soak.
I'm working with John Faddis at Quadstar Tuning right now to get a Champion radiator for the project.
I am going to install a temp sensor in the back plate of the passenger head with my stock radiator and run the truck on a certain route that includes 55 mph roads, freeway, and hills to get a baseline temp range. I will also get surface temps at certain areas that you recommend with an IR gun.
