you can use the JB weld but don't use the quick stuff, the slow curing one will hold better. Pinching the hole will only make it crack where the pin hole is making it worse plus harder for a radiator shop to do the repair when you have no other choice.
adding anything into the system to stop the leak will risk clogging up the heater core or hurting other things. this is a side of the road fix to get you home kinda thing.
best thing is to find exactly where it's leaking and get it repaired properly. if you have experience braising aluminum or know someone that can, that is the best thing next to having a radiator shop do it for you.
Wire brush and sand it ti shiny clean. Solder flux and solder and tin it up real good. Then the solder will bond as long as there is no grease or oil on the tube.
A soldering gun can doooh dat.
And if you use a bernzomatic torch to solder the leak, wet rags to keep the heat from spreading to other areas and loosening solder that dont need loosed.
A non 6.2 question here yall.
Ive come across Suburban bucket seats for a low price, im wondering if its possible to swap them into a K5 Blazer?
We're both 1990 Trucks (or his is 89), both bucket seats (mine is the photo of them with the seat cover)
Would it be possible to swap them? Is it a bolt in? (Attatched are photos of my mounting brackets) perhaps someone here with experience or a Suburban from this era can chime in
Screenshot_20260326_091702_Facebook.jpg20260326_105915.jpg20260326_115343.jpg20260326_115454.jpg
I believe they will fit. you may need to swap the seat tracks from your seats to the new ones. I believe 89 and 90 used the same ones, just options for with and without built in arm rests. @Big T has a 94 burb, he might know more about them and what it will take
Is it difficult to do that? I searched up Suburban seat brackets online and they look wildly different than the K5 ones
iirc there should be 4 bolts on the bottom of the seat frame, two per slide. can you post any pics of the base and brackets on the burb that's donating them?
Now compare to the bottom side of your seats where the brackets bolt up to the seat frame. the slide tracks are different but the seats should be mostly the same.
I have not done the swap on the two specific vehicles, but being both are 1990's, the bolt pattern should be the same on the bottom of the seats where the tracks attach. on the pic of yours, you need to look where the track is attached. there should be a single bolt holding each end of the track to the seat. those bolt points should also match up to the other seats.
ideally you need to pull a seat from both trucks and have them side by side upside down where you can look at them both.
start with the passenger side so you can still drive your rig while you are figuring things out. remove the tracks from both seats and see if the tracks from your seat will line up with the donor seat. worst case you might need to drill a hole or two and use regular bolt and nut. there should be some room to get a nut and wrench on the inside of the bottom seat frame for this. but that is worst case scenario.
If you use a regular bolt/ nut- you want to use a large heavy duty fender washer or chunk of steel with hole drilled in it as washer on the underneath side. Look how the nut like thing is made underneath the truck now. It’s not just a hole and nut. It’s made bigger to spread out the load across more surface area so that in a wreck the nut can’t tear through the body panel.
But using the seats that are there- if you swap the entire thing it should bolt in. I agree 100% do the passenger seat first so you can drive to the hardware store if needed.
This is one of those “don’t overthink it” jobs. Take out everything to the floor on the parts truck seats and into the bed of your K5 and take home if you can’t do it all in one day. Then take out the passenger seat of the K5 and set the other seat in its place. I would even flip them upside trying to compare- get it it place and start hand threading in bolts. If something doesn’t line up then post pics here.
I expect your having worry where there should be none
Well boys, been adhering the speed limit ever since the oil crisis kicked off (which is 55MPH), and ive been crusing at 55-65 (+70 if on a downward slope).
This is my current mileage, what do you all think? Previous readings were normally 13-15, only recently has it been this high.
What else could I do to better improve mileage? I dont even accelerate fast anymore.
(Interstate footage:
