1993 DB2 6.5, NV4500, HX35 Boost Control
Loganshaw_6
Surf City, NC
Hey guys, just finished installing an hx35 on the old 6.5 this weekend. Previously I had installed an HX40 but didn't pay any mind to the exhaust housing size. 18 cm was a little bit too big with the NV4500 so it made driving the truck almost miserable. Snagged and HX35 from a 12 valve a few weeks ago. My stupid question is has anybody found a way to manage max boost effectively in a manual transmission truck? I have a home made "waste gate controller" (spring, threaded rod, washers and a couple of nuts) but I'm trying to avoid if possible, the highs and lows of boost pressure. I don't necessarily need to cram 12-13 lbs of boost at 70 mph, 2500 rpm while cruising down the highway unloaded. Sure I can loosen tension on my spring and drop those numbers but I'm limiting my max boost. Fixed vane turbos don't work like VGTs I get that, my lmm Duramax takes care of this on it's own. Does stick vs auto make a large difference? It's obviously a DB2 not a DS4 so I'm even more limited but has anybody found a good "smarter" combo to manage boost for my setup? I'm guessing the answer is no.
Well I'm betting your spring is too strong or not strong enough... Home made isn't always better.
Keep running those numbers at a easy cruise and you will have more problems... I'd spend a few dollars and buy a turbo master with the correct spring and the correct geometry to start with... Or you could always use the setup that the turbo was designed with, a boost referenced controller and adjust it to the boost you want and forget about it...
I tested the truck with the original vacuum waste gate along with an adjustable elbow with the Allen set screw in the housing and I couldn't keep boost down. If I'm not mistaken don't the original hx35 waste gate actuators work off boost pressure? I went ahead and swapped over to the setup from the HX40. The spring could possibly be too tight.
Most all real holsets are boost controlled, the 40 is set around 20psi, so the assembly rod has to be adjusted, it's easy to get it close on a bench with a air hose and regulator, then fine tune it in the truck.
The boost pressure way won't move the arm like a spring does, that's why holsets use it...
Please post what it takes to get the boost pressure under control.
I have not done much to the truck recently I drive it more in the winter time. Plus with my commute doesn't always make sense to drive it to work. I'm picking back up on getting the pressure actuator set up properly along with some other needed maintenance. Hopefully I'll have a response soon as to what worked best.
I had a WH1C on my plow truck as it was nearly handed to me, installed with a PT Wiring setup actuator and hotside adapter. Always takes some trial and error with the home-brew stuff. I remember having issues settling the boost pressures once I first got it assembled and always wanted some type of consistent boost controller. My truck was an auto so I bet it was much less noticeable to me.
I have what I believe is the best set up I'm getting ready to sell... Unused modified HX351VE and new never used banshee controller.
As in you are going to sell the assemblies or you are going to sell your personal one and are going to something else?
And does anyone have a cozy used couch for sale if I buy this? I like my bed but my wife likes her savings account… somethings like burning my steak or getting a turbo is just worth the couch.
