Will L.
Leroy: winner winner chicken dinner! But being 14 months old I don't know if I would eat that chicken...
HiI solved this problem sometime last year but forgot to post the solution. Nothing is more frustrating than reading thru these threads without a definative answer! Anyway, it ended up having air locked in the fuel lines. I found a thread somewhere by Missy Goodwrench that gives the best procedure for bleeding out fresh fuel lines with a new IP. First, pull all the glow plugs. Then prime the system by turning the key to the on position for 45 seconds, you should hear the fuel pump rattling during this. This "prime" forces the fuel through the IP and back to the tank. Next crank for 20 seconds or so, watching the glow plug holes for fuel vapor squiring out. Repeat this entire procedure until all cylinders have a good fuel spray coming out of them. Also allow for stater to cool in between crank sessions. It took about 6 cycles of this until I had fuel coming out of all 8 glow plug holes. Re-installed the glow plugs and it fired right up! Thanks to all who replied, hope this helps someone else with similar no start symptoms.
Ok here is my original backstory. Sorry this got really long but this should be every detail I have.Jamez, welcome.
We need to make sure exactly what your situation is. Please fill out your signature line with truck details- especially any modifications. Pictures and videos are always helpful.
Do you have clear fuel line going into and out of the ip (injection pump)?
Any bubbles? Can you clearly see fuel flowing through it while cranking?
Was the truck in your possession-running before you swapped the ip?
What about pmd? Was it working and is the same one before you swapped the ip or are you using a new pmd that came on the new ip?
Have you hooked up a fuel pressure gauge at the ip after all the flexible fuel lines? What pressure?
With hard lines disconnected from all 8 injectors- is there any fuel coming out of any of the 8 lines?
What is your cranking rpm?
There are 10 questions. All 10 are CRITICAL.
There was bubbles there when I was priming and getting fuel there , the bubbles are all gone now.Ok. Fuel pressure going to the ds4 should be 8-14 psi. But so long as it has any pressure at all it should start & run.
The clear line - 1/4” diameter about 5” long that is in place for the ip return line-
Please post a pic of it so we see you have the correct location. Having a tiny bubble trapped in there is ok, but you should never see a flow of bubbles (or anything besides clean fuel flowing).
You already replaced the engine harness it sounds like, just double check you have all the grounds are good. One goofy one can cause chaos.
This sounds to me like an issue with the electronics of the ds4, so at that point I will step back as there are many guys here better than I am to chase the hiccups.
Will is my tach supposed to show something while cranking?Ok. Fuel pressure going to the ds4 should be 8-14 psi. But so long as it has any pressure at all it should start & run.
I’ll try to remember to watch the tach when I start my truck in the morning.Yes. I can’t remember any years where it doesn’t. Maybe others can speak up if some don’t.
Crap I thought mine did but I can’t remember and it’s definitely not nowYes. I can’t remember any years where it doesn’t. Maybe others can speak up if some don’t.
And I forgot to check my tach this morning.Crap I thought mine did but I can’t remember and it’s definitely not now
It’s ok I appreciate any help I can get.And I forgot to check my tach this morning.
Fass is wired with the harness they sent and is on and running when my key is in the run and start positions. My tank is clean as in sparkling clean, the sock looks brand new as well, but I also have the beans machine large bottom sump.Run through this even with FASS if your tank sock is plugged up you may not be getting fuel to IP, https://www.thetruckstop.us/forum/threads/lift-pumps-ops-operation-and-troubleshooting.6872/ also check gnd and power to the FASS pump those are pretty loud you should hear it running.
Where/how is your FASS connected for power?
I doubt you will see any rpm during cranking, the dash tach signal comes from the Alternator, the rpm the PCM uses comes from the crank sensor and optic sensor in the IP for backup rpm for PCM generally you need a real time scan tool to see those rpms.
