schiker
This is a handy little tool a battery powered pruning saw. This one was $60 has 2 batteries&charger with 3 chains from Amazon. It should last a year maybe 2 of light work. For real work I might buy a premier brand but for testing and trying method this one worked well. First battery lasted almost through a squirt bottle lost track of cuts.
My property has an abundance of Sweetgum trees and other unwanted under story trees/shrubs.
This year trying to thin out some stuff with the hack and squirt or frill and squirt. Now is the season. The hacking works but sometime vines, briars, and limbs limit your swing. Also, the skinny hack kerf then spray on blade slows procedure and makes swing next time sling off build up. Bigger trees need more hacks. This tool zips thru bark and can easily cut 2 or 3 large arcs and squirt with less effort. My method does sling saw chips back at you but that is all natural and better than the splatter of herbicide off a hatchet.
