Reassembling after a break…
No problem take it easy and recover. I’ll take care of it, I have a little bit of welding skill and an arc welder and mig and drill press. The thing I miss is in Illinois there was a scrap yard that would let you browse the yard and you could buy back what you could use. Another guy parting out GM Chevy parts is going to check and see if he has one. Thanks for the offer though. 🙏
Belson Steel?
Just stop in the office ,show id and they will give you a card with a number and you will be on file…so if you’re selling scrap or buying they pull up your number and collect or pay. It’s all in one small building weight it on the dock or big scale if you have a load. You can even drive your truck in the yard if you buy something big so you don’t have to drag to the scale.
I would like to apologize for ranting… off the topic of the post. I finally was able to locate the bracket for the alternator that was missing and glad I didn’t try to fabricate one…it is a well designed heavy duty bracket. I also drilled and taped a pyro probe before the turbo on exhaust. Sadly I need to pause for another break.
