chevyCowboy
when I started my truck this morning it started normally and then within half a second. seemed like the timing changed and it was running almost like it had a knock. didn't have time to mess with it right away so when I got home from work I hooked up the computer and these are the codes that I got. there was a bunch
I cleared the codes and fired the truck up. everything seems to be fine now. not sure which one I should look at. first. I went to the live data metering and all the timing stuff looks right. the TDC offset is a little far if I remember right. it's like -1.94 or something is the desired
I have been having a issue with this truck doing A weird surge but it does. it. super randomly and it could be weeks in between times it does it. I was guessing it is something to do with the injection pump being worn, when I add tranny fluid to the fuel it seems to do it less.
The other day it did it and then started running similar to what it did this. I shut the truck off And restarted it and it was fine after that.
anyone have any thoughts on this? thanks
