Fuel system setup
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
I need to replace my fuel sending unit. Planning to buy one of Leroy's versions - looks like he has 3. High performance with 1/2" pickup tube for $145, stock for $249, and then a different high performance with 1/2" pickup tube for $160
I have his Walbro lift pump now and the stock FFM.
I plan to keep the stock FFM. What are recommendations for which FSU and what to do with filtering, etc.?
I would say choose one of the high performance ones. what is the difference in them? I have heard the metrum rod is the best. at least I think that is what it's called. the 1/2" is cheaper than the stock and will give you room for later upgrades and activities if you so choose later down the road!
On sale, about $16. The $145 unit is just the rod. I have that and in my case, made the bouncing needle look more like a pole dancer twitching next to an ATM that only dispensed $1 bills.
I also dislike the fuel levels represented. Too long to explain fully. Just suffice it to say, I have only gone 60 miles when the gauge reads 3/4 remaining and 10 gal. left when the gauge reads empty.
Still, Maybe the full unit will work better...I'm about to give it a shot because I don't trust the quality of any of the OEM-ish products, it's about the same price on sale, and it can't be any worse than what I have now.
I have the fuel tank SU from Leroy Diesel.
It is far more accurate than the original stock unit and the gauge doesnt bounce around near so much.
The stock unit if the gauge got near the reddish colored low fuel marks I better be setting at a fuel pump or I most likely will not get to drive the truck under its own power. That happened twice.
The Leroy unit the gauge now reads very accurate.
Are either of you using the stock socket at the pickup tube?
I eliminated the sock. But I’m also running the air dog lift pump with its filtration system.
Before replacing these systems the PO had eliminated the tank sock and had installed a 3/8ths” inline steel shell fuel filter.
I'm using the OEM Diesel Tank Sock.
Marty, I'm glad the sending unit is working as advertised for ya. Did you buy the full replacement unit or just the metrum rod?
I purchased/replaced the entire unit.
This should have said "stock sock" but I think everyone picked up on my error.
I'm trying to see a need for 1/2" pickup tube aside from cost benefit. I've sent an email asking why the high performance version is so much less expensive than the stock style.
I have a stock sending unit that I purchased from RockAuto without realizing it wouldn't fit my cab & chassis dump truck. Vent hose is pointed a different direction. Anyways I had already cut off the fitting for the supply line and put on a tube nut and flared it for a -6AN fitting before realizing it wouldn't work. I was going to transition from that -6AN fitting to 1/2" fuel line. If you're interested at all shoot me a message. I know your truck doesn't see salt, I just can't stand the GM fuel fittings seizing up.
I don't use the sock, historically I've just put an inline mesh strainer pre lift pump but am now installing a water separator fuel filter pre lift pump, think its 10-15 microns. I haven't used the stock FFM for years, I use either a 2 or 5 micron filter from NAPA. I can share part numbers when I get back in town.
I did kinda the same thing last time I pulled the tank on the 95. eliminated the sock and cut the steel line about a foot or so in front of the tank. used to sections of 6" fuel line, double clamped to the steel line I cut and put an inline clear plastic fuel filter so I could see what it was catching.
of course this is what bit me in the arse when I was towing the 93 back from Houston TX. that fuel filter had plugged up and I forgot it was there!! went to replace the LP due to no fuel pressure and saw that filter full of sh!t!! replaced it and I was back on the road!
@SnowDrift that is a pretty decent and cheap setup at that price. I've run an even more basic mesh strainter from NAPA, 3/8" inlet and outlet so just cut out a section of the steel line and splice in with rubber hose
Nothing fancy, but super quick to swap out and can be re- used by just blowing out with compressed air. That evil energy unit you found is definitely a step up and I like that it can be cleaned and re- used.
I'll look in the shop tomorrow and see what spin on filter I'm using on the dump truck, it's either a 10 or 15 micron spin on water separator with a drain that is plumbed in pre lift pump. On my pickup I was using a large hydraulic filter as my fuel filter. Being a hydraulic filter it acted as a water separator too but I'm now more focused on very fine final filtration to play nice with the new DB2 pump. Hoping that having the water separation and final filtration handled by two different filters will prolong the life of both.
Ryan give me a holler you have my # I have been running Metrium rod for 10+ years with OEM sock which is 70 micron BTW, but I also run a 30 micron Racor filter/water sep. on frame rail prior to lift pumps, and stock 6 micron nominal (factory rating) in the FFM relocated to driver side fender on 1/2"-13 treaded studs.
(3) tier filtration so far has worked well, OEM "sock" also has built in check valve in event of gelling, or "algae snot" plugging sock. Look in photos in the linked post from the TRL it has images of factory and aftermarket "socks"
