I have a Penta marine engine, Tamd40, with nozzle DNOSD 193 and boostpressure 1.2 bar with Holset H1C turbo unit. . Ca 200 PS.You need to clarify “better”.
More volume at same pressure (generated by pump) will not mist as well.
What injection pump are you running and how it’s set up,
What compression and turbo are you running and what boost.
Then most importantly how are you using rig and what exactly are you trying to achieve.
Will the VW or Mercedes nozzles fit the 6.2/6.5 injectors ?Every IDI nozzle has the same size hole. I've measured the GM, VW and Mercedes nozzles and they are identical.
The difference comes down to the pintle design, and the amount of needle lift. As the needle lifts off the seat the design of the pintle and how far it lifts up determines the flow rate curve. The injection pump determines the volume.
Honestly I think marine injectors are a complete waste of time and money. Until I see real world test results (hp, mpg ect) I doubt they truly do anything. I believe the results people feel are just from the added pop pressure. Which is a whole different discussion.
Have you got the fuel delivery increased at the pump? add a little more timing advance maybe?I have a Penta marine engine, Tamd40, with nozzle DNOSD 193 and boostpressure 1.2 bar with Holset H1C turbo unit. . Ca 200 PS.
I don't need more power but enhanced torque.
Could DNOSD 314 or 315 be a better solution
They are all interchangeable. There are long and short style VW/Mercedes nozzles just like the 6.2/6.5. Out of all the nozzles I measured, the long body 6.2s are my choice for my build. Most amount of lift, the needle is larger, and with some modifications to the pintle I believe the flow rate curve can be dialed in for a more performance application.Will the VW or Mercedes nozzles fit the 6.2/6.5 injectors ?
Those are still available, made in Germany.
Thinking those nozzles and use the pintle from the old 6.2/6.5 injectors, check spray and then have a source for proper and premium nozzles.
Or if the pintles for the German injectors would work with the 6.2/6.5 injectors.![]()
So care to give us a part number for the ones that would be close to our electronic 6.5s?They are all interchangeable. There are long and short style VW/Mercedes nozzles just like the 6.2/6.5. Out of all the nozzles I measured, the long body 6.2s are my choice for my build. Most amount of lift, the needle is larger, and with some modifications to the pintle I believe the flow rate curve can be dialed in for a more performance application.
Yes, the Bosch VE6 gives 10% more fuel and timing is advanced with plunge lift adjusted from 1.80 mm to 1.90 mm.Have you got the fuel delivery increased at the pump? add a little more timing advance maybe?
Let me see if i can dig up those parts numbers. It been a few years since I messed around with all that.So care to give us a part number for the ones that would be close to our electronic 6.5s?
what I think everyone is asking is if the part number posted is the one for a suitable replacement for our electronic DS4 powered 6.5'sBosch 0434250176 is the part number for DNOSD 314
Stanadyne nozzles are just as good and I was getting them for $50 each from my supplier. Haven't checked current prices in a while though.what I think everyone is asking is if the part number posted is the one for a suitable replacement for our electronic DS4 powered 6.5's
apparently the original Bosch nozzle is ether NLA or a needle in a hey stack to find over all the cheap Chinese junk that's out there now.
I have a few set out that are in use. All good feedback so far not enough mileage on them to see how long they are lasting.I would be hard pressed to see stanandye as good as the GERMAN bosch. Good as the India- ok. But those German nozzles we used to get twice the life and then half the time sonic cleaning (which was more rare back then) could get them almost new again.
Track 10 sets to 200,000 miles and retest- then I could feel better.
The original standyne were reliable to 125,000 miles, so we still swapped them at the 100k mark.
Now, modern manufacturing processes have improved- so it is very possible. I don’t wanna sound like a nay sayer- just a tad on the skeptical side. Thinking about it, idk many guys running them currently- do you have many set out there cranking out the miles?
