I have less than 1000 hrs on the 4-53, it is in prime shape.
It'll fire up in a couple seconds without start fluid after sitting still 9 months out of the year.
I like to get 25-30 more ponies out of it so the SOB will pull my 567 baler without losing up to 500 RPM depending on the slope.
You can get it with a big turbo and injectors, I am way to far out to know the numbers but 2 years ago I helped a friend drop in a 170 hp or so new one, but he was like 10,000 into it iirc.for a complete assembly. You needing turbo kit complete is probably in the range of $3000 would be my guess. Nothing high on skill level, just time and knuckle skin.
For My friend in Ohio, you can overdrive the blower, but not like it's done on a gas hot rod engine. Your only going to pull a couple pounds of boost out of overdriving it. As for the no slobbering, don't worry, that will come with the boost. By the lug it has at idle and no oil blow, I would bet you are at under 1 psi on the driven side of the blower when at 2,000 rpm. The smaller cid like Bison's can build the boost easier because the the valve size to chamber ratio is way better for holding boost- Also why they die sooner when turbo is on it, 2 strokes cant breathe good under pressure. Definitely a turbo in your future for any power gains, but your going to have to figure what exactly you have before you start trying to get any parts other than the bypass. On the truck, It looks good,but I was thinking different headlights, see there goes my memory again. Good looking rig, reminds me of a modern Pete with an 80's KW bonnet. Too much there to chop into a lil truck. Think I would add power steering.
For both you guys, I am not real knowledgeable on these, there has got to be a forum out there somewhere that has all the info. I used to work on them a bit and did some turbo kits, and swapped several worn out blowers, but that was in a kit form, and the injectors were off the shelf. Take your time setting up the bypass, not hard but makes a difference in a smooth transition into boost. One thing that I didn't mention earlier is the airfilter. Depending what you currently have the air filter might be too small for the increased airflow.
I did one 8-71 that was turbo only, and not injectors. The customer didn't have the cash yet was planning on coming back for the injector job in a couple months. It helped so little without the injectors it was amazing. It could rev quicker with no load, but under load it was almost not noticeable, except it cleaned up his exhaust some. Putting in his injectors was the last job I did there (10 or 11 hour day)and boy he was a happy camper afterwards.
Hope some of my faded memory helps. If not maybe it can give a laugh- does to my wife every now and then.:wink5:
