Anyone run the Fierce Attitude tire?
The Coopers are gone after less than a week due to a bad few tires. Replaced them with LTX AT2's since there are so few choices in tires this size. Not happy.
Just cause I got a bubble in my tread doesn't mean you have to join the club ya know :nonod:
I just switched to these back in December after getting barely 30K on a set of B.F. Goodrich Commercial T/A Tractions. I liked the BFGs, and they got me into and back out of some places a 5 ton utility truck should never be expected to go (up some washed out "4x4 Only" fire roads in the Shenandoah National Forest to set up a radio network for a 500 mile motorcycle race on top of a mountain peak would be a good example), but they wore extremely fast, even with regular rotation (every other oil change). I'm hoping that the Firestones last a lot longer than that. I also was hoping for better fuel mileage, but that just seems to be getting worse instead of better. The truck used to get 11-12 mpg, which had dropped down to about 9.5 just before changing the tires. I found out when I changed them that my tire gauge had been reading wrong and I was running 10 psi under what I thought I was (45 vs the 55 that the gauge was showing), but mileage has not improved at all with the Firestones (just filled up and I'm down to 8.8, but I pushed the truck pretty hard at high speeds over the weekend) and may be getting worse. Not sure what's causing that but I'm keeping my eyes and ears open.So I thought I'd start a tire review thread. Please don't talk about tires you wish you had, etc. Just what you have, Pros/Cons, etc.
I'll start:
Firestone Transforce A/T 265/75R16 LR E. Good off-road traction, quiet, handle well, good tread pattern, but they are wearing fairly quickly, especially on the rear. I need to rotate them, but are still going to quick. They have 10k on them, and I'm expecting another 30-40k on them.
On a scale with 1 being the worst tire ever (loud, rides like a brick) and 10 being the best (quiet, soft, and great traction), I'd give these a solid 7.5. Not spectacular, but very good for a LR E truck tire.
Next!!
