Hello, new here but hopefully you can help.
Got a 6.5 turbo (center mount-H1 Hummer).
Primarily, began loosing coolant, low coolant light. Added water and notice coolant is nasty brownish greenish foamy gritty water. So flush, 6 times, new coolant. Now getting some erradic weird temp fluctuations, sometimes almost like themostats are sticking. Once warm and temp is up, is fine. Temp stays pretty stable at 190ish.
Not smoking, no white steam, No start up clouds of smoke, no puddles on the ground, runs great. Oil is beautiful jet black. No foamy milkshake. CDR valve clean, only oil. Uses just a bit of oil between changes.
Coolant now looks kinda ok but still has small brown lumps in it. Still loosing coolant. Constant pressure on coolant overflow tank, even immediately starting from cold. Constant bubbles and foam from upper bleeder screw and radiator bleeder.
Took it to a shop and they said, hey we're not comfortable repairing it and just replaing the head gasket but we will sell you a new engine--I said no thanks, engine has 60,000 on it, new in 2007.
New shop says, gotta pull the heads and look, if you got head warping, good sign, we replace. Also said, no head warping or no head cracking, bad, maybe worse problem. Confirmed some pressue loss in a couple cylinders. They want to check the radiator and head gaskets.
Any thoughts? Am i missing something?
