turbonator
Member
well i have started to mod the pass. fender for our k-47 air box... i took a 4" hole saw and drilled a hole directly in the position where the airbox picks up the air from the factory restriction in the fender..( had fun pulling that garbage out...LOL) i welded the piece of 4" exhaust into the hole, and took a old body style gm mirror cover and cut it to fit over the pipe and welded in place.... those covers make a sweet louvre and its OEM pieces...LOL... i will hook up the air box and test it with the AEM filter we have on the N/A 6.2l to see if it makes a difference, then will test it with the 6.2l turbo motor we are building...... so in effect it is the first 6.2l N/A i have seen with the k-47 air box....:thumbsup:... also pics will follow...
