handcannon
Due to some overheating when towing I'm checking out different brands of HO water pumps. This is for the 94 in my sig line. The radiator is a used one I found to replace the damaged stock rad that was on the truck when I got it. No overheating problems except when towing my TT up hills.
The rad is all brass, non aluminum core. I took the rad down to the local rad shop and had them go through it so it's clean inside and out. The AC condensor is new so it's clean. The oil and tranny coolers are clean. The thermo crossover was broken when I got the truck so I found a used dual thermo crossover. I have already changed out the fan and clutch to a DMax fan and 97 severe duty fan clutch. The only thing not changed is the water pump, it's still a stock 94 pump.
Rockauto shows a long list of pumps with widely varying prices. I've read that the 99 pumps were better output than the earlier ones so that is the year I will list. Many of these pumps were the same part number for 1997 through 1999. I'm not even considering reman pumps. My question is what brand have you used and how well has it held up? I will list the ones I'm considering.
Bosch #99153 $59.79
Airtex #AW5074 $63.99 (never heard of this brand before)
Gates #44042 $66.79
Cardone Select #5511130 $66.79
AC Delco #252717 $83.89
Rock Products #WP3195A $94.79
There were other new ones listed that were even cheaper but I'm leary of them. Maybe it's the guality of the bearings or other parts used?
Any info/firsthand experience you can give me will be appreciated.
Don
Bosch #99153 $59.79
Gates #44042 $66.79
Don
